International 1086 hitch pump replacement
Kory1998
What all gaskets or parts do I need to replace the rear hydraulic hitch pump . My tractor has open control center hydraulic should be a 12 GPM pump. Anyone got any recommendations where to buy a new pump.
What type of diagnostics have you performed to determine that your tractors hyd pump is faulty??
Over the last 50 yrs many hyd pumps have been replaced ""utilizing no to poor diagnostics"" to determine that the pump replaced was not the hyd problem.
Like said below BEFORE you drop some schekles on a pump if you can not have it tested then PAY someone that has a flow rater and see how many gallons a min. it is putting out at operating temp. and how it acts when a load is put on it . Have you checked the hyd. filter ?? is your Hyd oil more water then oil ??? is there any hdy. oil in the tractor ?? How many working hours are on it ?? . That one little piece of test equipment that rides around in my truck has save people money and made me money all at the same time . This is NOT something that everybody that twists a wrench has . I am the only independent anywhere close that has one in my neck of the woods.
Tractor has 8200 hrs on tach
Drive it down road and ran it up to operating temp, seems to work a little better on hydraulics. I have bought filter and 30 gallons of oil will drain and flush oil
