International 2000 loader
SCOTTRS
I purchased a International 2000 loader to put on my 656 and I have a question. One of the dump cylinders is leaking pretty bad so I went to Case/IH to get the rebuild kit (Wow what a price).My question is how do you get the retaining ring out. Apparently the previous owner turned the nut and broke the L-end of the ring off. I couldn"t by turning the nut myself get the ring to move to where I would have an end to get a hold of it so I drilled the ring to break it and pried it enough to grab it with vice grips. The ring would not ride out by turning the nut. I then tried hammering the vice grips that was clamped to the ring to get it to move out but it would not budge and then finally broke to where I can"t grab it and the ring still wont move by turning the nut either way. Anyone ever run into this or know of a way to get the ring out in its present position?
I can't answer your question. I do however have a 2000 loader on a 706. The cylinders were leaking and I didn't really have time so I took all four off and down to my local machine shop. He machined them to accept common/modern seals. Total bill was $250 four all four cylinders. Might be worth checking with a local shop and return the CNH parts.
Casey in SD
Casey in SD,
Thanks for the reply and great info. I never considered a machine shop because I thought it would be 250.00 to walk in the door. I am stuck right now not being able to get the cylinder nut off. Not having ever rebuilt a lift cylinder I figured it would take 3 hours. I have twice that time just trying to get the retainer ring out and I haven't made much progress. I guess I need to be thinking about plan b and c.
Thanks Again,
Scott
I see you have a 2000 on a 706 Iam putting one on my now and have no front brackets could you send pic so I now what height to mount the front at I have the back arms under rear axle hope to hear from you Thanks John
