international 240 help
buckshot
hay all need a little help finding a part for a 1958 international 240 utility i need the hose and tube for the hydralic system the part # is 371304r91 have been told it has changed to 378832r91 or if anyone has a good way to change just the hose. or a good used one for sale thanks for any help i can get
If it is to the hitch, block it up well, and remove the existing hose. (cut it in half if needed)
Take it to Fleet supply store, or a hydraulic shop, and have it duplicated (with swivels/unions as needed to allow easy assembly) Make sure it is of approved pressure hose, and inner diameter. If a check restrictor is on the end at the cylinder, make sure to use it in the new replacement. JimN
