international 240 utility
iso
i purchesed a 240 utility the hydrolic pump is leaking in a few places and need to relace some hoses also where is a good place to find parts need manual also.any help would be great.also looking for a good loader for it.thank you for any help i can get
found a pump for mine on ebay -- about 30.00 compared to about 500.00 for a new one. My tractor was a piece of crap hope you have better luck with yours
try wengers . com , go to parts search, then select international, then 240. they have a bunch of used 240 parts available. i have a 240u and have the operators manual and the preventitive maintenance manual. if you need specifics, let me know,i can either scan the pages for you and email or fax you the info. my email is always open. glenn
As for a loader, I have a Westendorf TA25 on mine. It is probably a little heavy for the tractor. I suggest that whatever loader you buy, make sure you can remove it when you don't need it.
found the rear hub was bad need to find a new one also tag on side of bellhousing says 607 j cant find any info on it. is there a gasket set you can get for hydro pump.yea i got screwed on this one guy was really good at hiding things till i got it home and all startwd going to -ell. any info would great and thaks in advance for any help
