international 309a plow ?
gstout
I recently bought a 309a international plow, 3 bottom, 14". An old manual that I found says to set inside of rear tire to center of tractor @ 23". with tractor set this way the plow still won't run correctly, wants to pull to the left, I have adjusted the crossbar to set the lead, but can't get this one figured out. btw put on new shares, shins and landslides, all ih parts that fit perfectly, there's something i'm missing but don't know what it is. I would be thankful for any suggestions . thank you in advance.
good evening gstout, a question, on the front and center molboard the landsides should be the same length and shorter than the rear molboard, the rear lanside should be about 6 to 8" longer than the front 2? or do you have the angled furrow wheel behind the rear molboard? john
