International 350 utility
RodneyD
I have a international 350 utility with spin out rims. The rims and tires are in really bad shape. I have found a Ferguson tractor that has pretty rims and tires on it and was wondering if they would work on the 350 ?
Are you looking to change the outer rims and the centers?
If so, as long as the bolt patterns and center holes are the same,
and the rim/tire diameter and width are close, they should fit.
You didn't mention what model Fergy, but most of the earlier ones
had an 8 bolt on 6 inch pattern like the Fords. I thought the IH
had a larger bolt pattern, but I don't remember for sure.
If you're just talking about swapping the outer rims onto your
centers then we'd probably need to know a lot more about them.
There is fair odds that it will work. take some measurements of track to track diameter, and track bar dimensions. They were made
by others for IH, and in my opinion likely to be the same. Jim
Different bolt pattern at the hubs I believe. IH will be 8" c/c, MF will be 6" c/c. If I am wrong, I'm sure Someone will correct me.
If the tires are both 28" and 4 bar spinouts it is almost a certainty that the rims will interchange. I doubt the wheel centers will interchange.
