International 350 Utility
I can't remember the exact gallons though it seems to be in the 11 gallon area. Hytran, or JD hydraulic transmission oil are the correct oil Other good quality that meets the IH or JD spec for hydraulic and transmission service will do as well.
There is a level plug on the left side under the foot plate (if I remember correctly) and the TA if drained will take less than a gallon. (it is fed oil through the front of the trans while running) Drain all the plugs under the tractor to be sure all oil is out of the sumps. The chambers interconnect, to the fill plug near the shifter, but drain independently.
The Hydraulic fluid is not mixed with the trans fluid, but both are Hytran. It is filled under the seat where there is a dipstick.
Go with either 10 40 auto oil. or 15 40 diesel grade oil for the engine. JimN
