This message is a reply to an archived post by d7Fever on January 27, 2016 at 18:18:31.
The original subject was "IH 3850 wheel loader".
No parts are a available using part numbers for steering. I just replaced both of the tie rod ends and the steering cylinder end. The matching part was SA HES2035R. The steering end had to be altered. I used a grinder "chop saw" (10" thin grinding wheel with vise at base to hold part) and cut off the 1" threads from the new eye, then cut off the female component of the old cylinder end. I then welded the female threads to the new eye. It worked perfectly. My parts tie rod ends cost $27.69 each and I got them from Traction Heavy Duty Parts 850-432-6272
I need a radiator for my 3850. Any ideas?
