International 404
I have a 404 that will quit running when I throttle it up.
I found that there is a weak spark ( not a crisp blue)at the plug wires when its idling and no spark when throttling it up.
I have replaced the points and condenser and the coil has great spark.
I have noiticed that the distrbutor shaft has a little play (side to side) in it and also I can turn the rotor back and forth I think more than normal.
My question is, Is there something else that can be worn between the dist. and the front cover.
Thanks for any help!
Some years ago the distribuitor drive on my Farmall Super C wore enough that it jumped about 4 teeth. It quit running at that point. It wasent untill that the dist was removed from the tractor and completly taken apart that the problem was found.
Turned out to be the 6 volt coil and the resistor was bad.
I updated it with a 12 volt coil which the newer models come with and it runs like new!
(quoted from post at 21:44:29 11/20/09) Turned out to be the 6 volt coil and the resistor was bad.
Actually, the newer models, like the 444, use the same 6 volt coil as yours. The difference is that the resistor block went away in favor of a resistance wire between the ignition switch and the starter solenoid.
The main advantage to using the 6 volt coil with resistor is in starting. Cranking voltage may drop to nine or ten volts while cranking the engine. The lower voltage will cause you to have a weaker spark as the engine cranks over. By using the resistor, instead of the nominal 6 volts you have while the engine is operating, you now have nine or ten volts for a hotter spark when starting.
