International 606 front pivot problem
reltor
I have got a 606 with a rigged together front pivot that appears to be a piece of pipe with pipe endcaps on it. The fit is sloppy the front of the tractor is too low and the steering arms are dangerously close to the oil pan.
I can have a new pin and bushings made, but I don"t have any idea of what the original pin looked like. Does anyone out there have a schematic, or picture, or know if this tractor used the same pin and bolster as any others? Thanks.
Go to caseih.com and do a search for parts. Put in 606 and look under front axle. The drawing is right there.
Thanks, that schematic from caseih.com really helped. I re-bushed my bracket and have a new pin and lock made from 4140 with a grease fitting, just like the original except I ran a grease groove back the the axle instead of just ouputting at the bushing. I found the small end of the steering arms need bushings too.
