Bob Zerunkle
Hello everyone,
This winter I purchased by first farm tractor, a 1960 B-275. I followed this with a running but really just-for-parts B-250. Preparing for this year I have changed all the fluids in the 275, replaced the PTO seal, upgraded the glow plugs and have learned quite a bit. Now I seem to be stuck, literally.
I just got a 5' bush hog thats worth more than the tractor. PTO clutch is slow going (same with transmission) and I am working on that and will probably end up making a seperate post for those interested in helping me out. But right now my problems lies with the 3 point hitch.
I am able to lift attachments just fine. However the 3 point hitch does slowly drop over time when it is holding weight. I am not sure of how common this is, but in reading I did learn about the draft control. It was working great to hold attachments at the height i wanted until it got stuck at the bottom. My 275 is equipped with the draft control dial. I had it spun all the way down when using a scraper blade to make garden rows. Now I cannot get it to turn back. In fact it will not turn at all. Even with the arms up all the way, I cannot get the dial to budge. It feels locked as if there is currently weight on it. I have downloaded the full service manual for my tractor and there is very limited information there to help me. Even in reading about the isolating valve, it is only represented in a diagram and not mentioned again. So pardon my ignorance, but does someone know if the isolating valve could effect these settings? Do I have to turn it to the right spot? I do not know where to go from here. I need to cut some fields and trying to readjust the bush hog height while trying to make turns up/down hills is just not going to cut it. I appreciate everyone's time.
