International B414
GwLung
I was wondering if anyone had a B414 parts tractor. Im
looking for the sheet metal piece that the tachometer mounts
in and the bigger sheet metal piece below that. Both pieces
bolt on under the steering column. Ive tried calling a few
national salvage companies that post pictures of B414s with
those pieces and all they do is tell me theyll call me back and
Ive heard nothing from them. Im also not sure if the 434 or
444 has the same sheet metal. The parts book doesnt show
the small piece that holds the tachometer but it does show the
larger piece below. It calls it a scuttle
Im also looking for the piece that bolts to the right fender with
the teeth on it to set the parking brake. Thanks to anyone who
could help me out.
Try Stephen at Ontario Used Tractor Parts 519 523 4922 . Stephen ships world wide and is a good guy to deal with. I know he has British International parts.
Sorry but I can not help you as the 434 and the 444 are not the same. Here in the UK the B614 and the 634 tractors were built at the Doncaster factory and the 434 and 444 tractors were built at the Bradford factory. MJ.
