International Cub Lo Boy
Kelly Wolf
I am a first time International Cub Lo Boy owner with serial number 24352 J. I was wondering were to put the transmission lube in and what weight to use. It looks like their is a place right behind the gear shifter but I want to make sure I,m right. Thanks for all your great help on this. Kelly W.
That is the fill plug. The check plug is o the leftg side about 2 inches above the bottom of tranny. A small pipe plug. It only holds about 3-1/2 pints of oil. Overfilling will let the oil leak out past the axles and onto the brakes. It would probably be a good idea to drain and refill since they have a tendancy to accumulate water in the oil. Use 85W 90 oil.
Sorry about that... I just noticed the link didn't "take".
(You'll have to cut and paste.)
http://www.cleancomputes.com/Cub/
