international harvester 330 throttle problems
Scott74
I am trying to figure out why when I start the tractor it runs great, but as soon as I throttle up it will begin to spit and sputter, and then shut off. I then can"t get it started to hours later. I have changed the fuel filter, the float, and spark plugs. There is plenty of gas getting to the carberator. I am at a loss....
(quoted from post at 19:14:15 11/21/11) I am trying to figure out why when I start the tractor it runs great, but as soon as I throttle up it will begin to spit and sputter, and then shut off. I then can"t get it started to hours later. I have changed the fuel filter, the float, and spark plugs. There is plenty of gas getting to the carberator. I am at a loss....
Fuel problems will quite often mimic ignition problems, and vice-versa, so it is always a guessing game. You say there is plenty of gas getting to the carburetor, but is that gas actually getting INSIDE the carburetor? There SHOULD be a fine mesh screen in the carburetor fuel inlet fitting. If that screen is plugged with rust and crud, the tractor will not run. Likewise the float valve (needle) might be stuck, or the float itself itself might be stuck, both of which will prevent fuel from getting in. Quick way to check is to remove the drain plug from the carburetor bowl and then turn the fuel on at the sediment bowl. If all is well inside the carb, there will be a virtual FLOOD of gasoline from that drain hole. If there is only a trickle, it is time to open the carb and see why.
