International identification possibly a 2424
I recently bought a International tractor with back hoe and loader attachments. I am having trouble identifying tractor id plate was painted over and previous owner sanded it off taking identification numbers with it. There is a number 7518 J deeply stamped in plate all I can read. Any help would be greatly appreciated. I am needing some parts but without Identification numbers it?s a crapshoot. Tractor has a gas engine 4 speeds plus reverse and has high and low range. It had a generator and was switched to a alternator.
From looks it sure could be a 2424, but likely the number you are seeing on the "tag" is the serial number and that's way tp high for a 2424.
NOT sure if it could be a 3414, their serial numbers got up in the 7000 range.
You can peruse the link below and see what else it may look like, there's photos of most of the models listed.
IH Industrial
I checked that site it would be a 67 model then. Most 3414 I see in pictures have square rear fenders with lights in them mine are rounded with no lights ?
Did you look at photos of some of the other models?
3414 was just a guess and the serial number is in that series, probably some other model exists with a serial number in that range, as well.
I have a 424 diesel, it has rounded fenders, and IIRC, the serial number is in the 2000 to 3000 range.
I have been looking yes. And thank you very much for your information by the way. I see similarities in several models but also deference?s as well. The main reason I am needing identification is for parts. I have already bought parts that are incorrect and that can be costly. I am trying to find a hand pump or steering motor. Mine has shaft coming out bottom with linkage attached while the 2424 only has hydraulic lines with no linkage. I will attach photo of mine.
Well this is something. I just contacted a tractor parts place here in Missouri who specializes in international tractors they told me it looked to be a 2504 and I found a place listing serial numbers which would make it a 1964. I hope that date codes on parts will help me narrow this down as well.
That tractor is a curiosity to me. Some things have a resemblance to a 2504 but others do not. I have a 504 which is same as 2504 and I know for certain that 504 2504 404 2404 424 2424 2444 do not have a universal joint on the underside of the power steering hand pump. I looked at many tractors on Case IH parts website and found none that do have a U-joint beneath the hand pump. Can you make a close photo of the steering wheel instrument panel area and the small square seen on the side of loader frame in the picture below? Also pictures of the rear axle, brake housings, front axle or any other areas that we can possible recognize some feature that could lead us to identify that tractor. I have IH loader parts book and there is no loader that looks like yours in the book.
Okay, after re-reading your statement that your tractor has 4 speeds and reverse and that you are looking for power steering motor hand pump, I figured out that yours does not have it or you mistakenly think that it does. Anyhow in looking at the 404 parts book, I see that 404 tractors without power steering have parts that are identical to what you picture with the U joints. You have a 2404 tractor.
A 404 without power steering pictured below. Notice steering shaft angled downward and forward from steering wheel, then U-joint and shaft continuing forward beside lower side of engine to front axle. Yours is like this, I assume?
Ok after much more research today and with the help of a very knowledgeable gentleman at JP tractor salvage in FREDERICKTOWN Mo I am pretty sure I have a 1964 2404 with a Massey-Ferguson loader and back hoe attached. With a Char Lynn power steering generator that?s not cheap. I currently have hydraulic fluid leaking from steering wheel is why I am desperately searching for information to get correct parts.
