international offset disc
Select a disk blade from any manufacturer with a heavy gauge and the diameter you want... and cut your own hex in it.
Disk blades for oil bath axles are going to be difficult to find. Komatsu was the last owner of the construction division to have any parts for this unit that I know of. But doing it that way is going to be slow and expensive, if possible at all.
The nut is cast iron, don't go pounding on it or it will fracture. Find 2 pipe wrenches that you can just barely lift, and start there. Unless you have access to an impact and a 5-3/8 socket.
Where can I find disc blades for a international offset disc model 24-b
Ive pulled those 24-Bs over more acres than I care to count. We had 4 of them total. They were good for our smaller plots, 10 - 15 acres and we could do several plots in a day like that. Our bigger plots we would tank all 4 and 4 tractors and do those. We did that for a few years then, as our tracors got bigger, so did the rest of our equipment.
Anyways, if we broke a disc on one of those or whe nthey just plain wore out, new disc came from either the local, gulp, John Deere dealer, or Ford tractor dealer.
