SkipperII
As one of the original;" Computers, I'll never use one" types, I've come a long way.
Got up yesterday, about 24 deg., outside, not much warmer inside, and the furnace blower was running, with no heat. Ran the thermostat setting down, the furnace shut off. Raised the setting, furnaced fired up, ran about 5 seconds, then the flame shut off, tried it again, same result. Grabbed my little electric heater out of the shop, so the Mrs. would have a little heat when she got up. Got on the laptop, entered the symptoms, it says possibly the flame sensor (electronic). A couple you tube sites pop up, so I watch, the guy show about where it should be located, and explains that they carbon up, and can be cleaned, Huh!, that sounds logical. Decide I need a second opinion, so I watch the next one. This buy is a bit more refined, says to use a brass brush, or one of the plastic pot scrubbers, but not to use steel wool, or anything else that will scratch it. Ok; armed with this information, time for some surgery.. Of course, I have to have, the model that the sensor is behind the gas pipes, and a transformer. After trying every 1/4" socket and universal that I own, I finally find a long end wrench, and unscrew the little 1/4" head sheet metal screw, and get the sensor out. It doesn't look like much carbon build up, just like a piece of steel rod that has been in a clean flame. Oh, well, I guess I won't loose much, but a few minutes, to polish is, and put it back in, Grab the abrasive pad the Mrs. uses to clean her polished stainless pans, without her looking. I give the sensor rod a good polishing, and put it back in. Now; how do I get the little screw back in the hole, and started, it's in a really tight spot for 78 year old fingers. I remember that I have a set of magnetic sockets for my electric screw driver, it worked. Go in the house, turn up the thermostat, and it fire up, and stays running. Now today, I have to reprogram the stupid thermostat, because I changed the batteries, and lost the programming. Back to the computer for instructions with letters big enough for old eyes.
