Irrigation gpm or gph
My math tells me that if I get one inch of rain on an 80 acre field that equals just over 15,000 gallons of water.
How long would you have to run your irrigator to put that much water on your field?
Just curious.
Dave
Depends on the size of the pump, sprinkler heads, distribution.
Simplest thing to do is lay several cake pans in the area and measure the amount of water they collect over a period of time......then do some math. That'll tell ya how long you need to run it to get a measurable amount of water on the ground.
My math comes to ~2,100,000 gallons to put one inch of water on 80 acres. Irrigation types, pumps, etc will vary widely, but from my experience, it will take 24+ hours for a center pivot in my area to make a full pass. 2,100,000/24 hours/60minutes/hour= 1,450 gallons/min needed. Most wells I know of in the area produce 600-900 gpm.
(quoted from post at 12:43:40 09/19/20) My math tells me that if I get one inch of rain on an 80 acre field that equals just over 15,000 gallons of water.
Just curious.
Dave
ad math. See IHRED
(quoted from post at 14:27:22 09/19/20) Oops, my bad. I now come up with 181,000 gallons = one inch of rain on 80 acres. Am I still wrong?
Dave
3,560sq ft/acre X 80 acres X 1/12 foot X 7.48 gallons/ cu ft= 2,172,192gallons
