Is it just me or does anyone else.......
JimNC
....make working on these simple tractors hard? Had trouble starting the 8N, has been running bad also. I started trouble shooting: checked spark with fancy tool that lights up when plug fires, was getting fire to one plug. Checked volts at bat, checked volts at resistor, checked volts to coil, checked plug wires, had 2 bad. Replaced plugs and wires, still no start, pulled carb: why? just to make simple job harder. cleaned carb, still no start. give it shot of starting fluid, didn't fire. FINALLY after really looking at points (which I had already CHECKED to see if they were arcing, I noticed they were not opening when distributor was turning. Checked gap (maybe had 1000th) set gap to spec and Boom purrs like a kitten. Does anyone put lube on distributor lobes, only thing I can figure is it wore the tab on the points down to close gap that much. Oh and my lack of regular tune up practice. Been gone from the forum awhile, glad to be back.
I thought the same thing but the screws were tight. Gotta get some points lube and a good set of points.
The last points I bought from Napa (Echlin, I think) came with a little capsule of point lube in the same box.
Most any tiny dab of grease will work. Most important is that the cam lobe is smooth, even light rust will grind away the plastic on the points
The points on my tractor would wear the rub block, even with the lube. I put on an electronic ignition module and the point problem when in the trash.
As Hobo said, ditch the light and get an adjustable gap spark checker. Re points lube, see tips 66, 67, & 68 at the link. Quality points, lube and annual adjustment are critical to top performance.
75 Tips
well yesterday one of my Fergusons developed a miss. so I located the misfiring plug and replaced it with a new one. started the eng. back up and it was still misfiring. so I drive around for a wee bit hoping the plug that was misfiring would clean itself. no such luck. got off the tractor and discovered I did NOT reattach the spark plug wire!!!***%%%###@+++
put the wire back on and the eng. is once again running smooth. I AM getting to old for this stuff.
Jim, Like Hobo said ya need both kinds in your toolbox.
The light helps you find a random missing troublemaker under load conditions, but that adjustable spark checker lets you look for spark 'muscle'.
(I will admit to getting by without one for a long time, now it is always in my pocket.........no more zaps..life is good)
(quoted from post at 12:04:07 10/23/15) well yesterday one of my Fergusons developed a miss. so I located the misfiring plug and replaced it with a new one. started the eng. back up and it was still misfiring. so I drive around for a wee bit hoping the plug that was misfiring would clean itself. no such luck. got off the tractor and discovered I did NOT reattach the spark plug wire!!!***%%%###@+++
Good one!
had a gas 5000, working its loader very hard one day. Digging into the pile, suddenly..very bad miss....feeling of doom on the long
sputtering ride to the shop....popped the hood thinking this is going to be expensive....loose plug in number 3..compression popped the plug wire completely off....whew!
