Is it safe to sleeve?
moocowman
I have a 4 cylinder Komatsu diesel engine, made by Yanmar. The engine model is s4d84e-5kfd. The cylinders don't have liners. 2 cylinders were scratched by the pistons. It needs to be machined for +.50 mm pistons and rings, but rings and pistons are only available in standard or +.25 mm. Most engines S4D84 model engines used liners. So, I can get rebuild kits with liners and use standard size pistons and rings. Is it safe to have the cylinders machine for liners?
Native block wall thickness is the deciding factor. If the replacement sleeve is a dry sleeve, and thin, it might be possible.
Wall thickness and core alignment in the casting of the block drives that factor. If the replacement sleeve is a wet sleeve, I
don't think it will work. If a repair sleeve is installed that is not much larger than the existing bore, (maybe 3mm) then that
bored to OEM size, you would have a solid solution. Jim
Thin wall press in sleeves are available
for that type of repair. As for being an
option on that particular engine that
question is best answered by a reputable
shop that preforms the work. If you are
near NW Ohio I highly recommend Harts in
Cecil Ohio.
