Is there a trick to putting the wheels on a VC?
I installed one wheel and torqued the 5/8 gr 5, 2&1/2 in long bolts to 110 lbs. The clips slide out as you tighten the bolts. one bolt has about 1/8 inch sticking out of the nut. The rest are all sticking out farther. One about 5/16 inch. This looks like the wheel might not be perfectly centered. Could this be a problem? Or will that be OK?
