CitrusGrower
Can any of you experts tell me if this is a Ford 2000? I can't find an ID plate anywhere. Diesel engine.
(quoted from post at 22:01:17 11/27/21)
Tractor was built July 17 1986 on day shift
Serial number is for a tractor built in the US in 86
Serial number search shows the tractor to be a 340B utility
The actual model numbers is in that rough area behind the numbers you cleaned off, a little more cleaning behind the number you've found will expose them
Model code for a 340B should be CU41?F
CU4 = 340B utility
1 = diesel engine
? = pto type, 1 = no pto, 4 = independent 540 pto
F = 4x4 torque converter auto reversing trans
This post was edited by Destroked 450 on 11/27/2021 at 06:07 pm.
(quoted from post at 20:05:03 11/28/21)
If you go to CNH parts look up web site you have the option of looking up parts by serial number
Punching in the serial number listed brought up a 340B model
Serial number look up doesnt work on the older thousand series but I think I was able to look up my 6600 and know it worked on my 6610
I didnt take time to look up the pto info
