The 8N I picked up ended up having a cracked block. This was
repaired long ago with solder. And as you can see there are two
lateral cracks as well as a vertical. Since there is no pressure on this
block would JB weld be the best option? It was built out quite a bit
with the solder and has obviously worked this long. Just need to
know wether to scrap it or fix it. Id like to fix it if possible.
