Its not Monday but
Oops
Always best to think a situation through before acting.
You would think someone would take in to account that long trailers will be using the road, when it was designed. Stan
Thats the levee for the Mississippi river.
They allow you to build a road across it to access the batcher area but you can not alter the shape of the levee.
There is a road about a block down that goes to the same business this road goes to.
It is built on an angle so it gradually crosses rather than straight up and straight down.
This road he tried to cross on is for tandem dump trucks with no trailers.
So the short answer is he just used the wrong road.
No problem just raise the air bags up on the leveling valve if close to making it over go on if not then back out and use a different road. I've done that to get under bridges with high loads where the state sent us in bad places under bridges. I let them down for that though.
One of the ag suppliers built a second warehouse here behind the first one. The new driveway passes the first and connects to the second building. It is maybe 700 feet long, and has 4 different angles in that distance to follow topography. None of them are level all angled so there isnt even a flat loading spot. A dip in the middle Quite steep. It is nuts stupid. I expect to see concrete gouges when I go back as landing gear and bumpers will be scraping hard.
Also the concrete between the driveway and older building is steeply sloped, not a retaining wall. So forklift has no room to come in on a trailer side, they get into the steep slope which is not comparable with a forklift!
Some engineer sitting at a desk never ran a forklift or truck or trailer......
Paul
