J.D. 216 Flex Head weight
Paul swpa
Anyone have an idea of what a JD 216 flex head would weigh? It's not in my manual.
Still working out plans for a header cart. Don't want to get too light of spindles/tires.
That is what I have now, a little 4-5 ton gear but it is too high and I am looking at changing the hubs to use smaller tires as I haven't been able to find small rims/tires to fit my hubs. Don't want too light weight capacitiy on the smaller tires.
check shoup, they got the little tire and rim assemblies you need for standard ag bolt patterns, not cheap but exactly what is needed, I think I paid $100 each last year
I had seen those tire/rim assemblies in the Shoup catalog, $130 now. Not real sure if they will be low enough (20.5") for me. Lifted the header up today and measured underneath to ground, had about 22", pretty close. In an earlier post I made, someone had used 5.70 X 8 wheels on their cart for the setup that I have. Checked at Tractor Supply this evening and a 5.70 X 8 tire is about 18" high but weight rateing is only 715 lbs. (only 4 ply) and rims don't match my hub bolt pattern. No luck finding different hubs for the spindles to fit the 8" rims either. Will probably just have to order the Shoup tires and live with what it turns out to be.
