(quoted from post at 19:51:40 07/03/22) use only one 12 volt , keep it simple. what do you mean where are they connected to the starter. follow the cable.
(quoted from post at 18:55:25 07/03/22) Can someone explain if it is possible to use two 12v batteries instead of four 6v batteries in an electric start j d 830 and if so, how to connect them and where they are connected to the starter. Thanks for any help.
(quoted from post at 08:57:12 07/05/22)
iirc there is a diagram in the operator s manual .
Use the highest CCA batteries that will cram into the battery box .
(quoted from post at 09:44:29 07/05/22)(quoted from post at 08:57:12 07/05/22)
b&d
I'll bet there isn't a wiring diagram in 830 operator's manual equipped with 2 cyl engine describing attaching two(2) twelve volt batteries similar to what ghunziker is requesting.
Jim
(quoted from post at 09:29:12 07/06/22)
If he can not figure it out from the diagram . He should not be using tools .
