Jacobsen chief 1200,
toeknee
I bought this to merely run around my property on, it turned out to be great little machine got me everywhere I needed to go always started even pushed Rock, dirt and snow with it. Then the shifter arm just came out, I don't have a clue where to buy the parts or how to fix it...any suggestions would be appreciated
.i
Looks like this is a gear drive shifter, an H-type pattern? The ball at the very bottom fits into forks or slide rails that move the gears into position, 1st, 2nd, 3rd, reverse.
Above that looks like a locking collar that keeps the shifter in the transmission. Could be a quarter-turn slot that lines up with dowel pins or set screws in the shifter tower of the transmission. That slot may be worn.
A picture of just the shifter shaft and end would help. I zoomed way in to see it on the console there.
Also there is a garden tractor subforum down the menu, under miscellaneous. Might get some Jacobsen experts on there.
