Jacobsen HR15 Transmission Problem
Fargo
Hi All
Bought an HR 15 and it cuts well. It has the standard 4 speed trans.
Here is the problem:
There is no cover for the clutch and flywheel housing and grass is getting up in there. Need the cover.
Here are the questions:
What transmission is it (heard it was Ford but cannot confirm)?
What model trans?
Where can I get a cover?
Thank you!!!
The clutch and transmission are pretty much closed areas. It is a typical truck 4 speed trans I can see it in some on line images. I would search Ebay vendors for the sheet metal floor pan (assuming that is what you need). If no joy, make a cardboard mockup, and have one made that will work. 14 gauge mild steel will be tough enough. Jim
some maybe pics
