Last week I installed a new starter motor (12V) and Bendix drive into my (12v converted) 8N. The new Bendix has the newer "coarser" spiral. After installed, I tested the startup a few times and everything engaged and worked great.
Today, I started the tractor and it immediately had a loud "ratcheting" sound coming from the starter. I immediately shut the engine off and repeated the startup two more times, all with the same loud noise.
I decided to remove the motor for inspection, but after the through-bolts were removed, the motor would barely wiggle, and not come free. Eventually, the front end cap and housing became unseated and I slid them from the armature and remaining end cap. The rear end cap and armature are now stuck in place.
By rocking the tractor in gear, the armature turned a bit and wiggles, but there is less than a quarter-inch clearance between the end cap and tractor mounting surface. I'm stumped as to what is hanging up, and, how to proceed in getting the parts free from the engine. When I installed the motor, I inspected the teeth on the flywheel ring gear and they appeared fine.
Any help would be appreciated. I saw a similar post on here and it was recommended to simply pry between the end plate and the tractor mounting surface. Any advice on that, or any other method? Thanks!
