(quoted from post at 08:02:05 05/08/23) Im repairing a gas tank and need to know how to remove the previous JB Weld patch. Will heat remove it or is a grinder the best option?
Is the tank or plastic? If metal I wouldn't grind on it. If plastic my experience is JB doesn't work real good
Best would be to use a blending disc. , not a Grinding disc. It will do a good job and not grind the metal away.
The fact that a JB weld repair has to be redone tells its own story. My gas tank repair with JB weld was good for two years and then gave out. I used Permatex gas tank repair the next time and it's a permanent success.
