JCB 1400B Clutch Issue
billwlkr
Hello all. I"ve recently become the owner of a JCB 1400B backhoe (Perkins diesel; non-electrical transmission). The backhoe works great with the exception of the clutch, which seems to be stuck in position. I can use the forward/reverse selector arm to go forwards and backwards, but the only way I can get the machine to stop is to push the selector arm into the neutral position.
When I press the clutch in, the attached arm underneath the machine moves away from the transmission, as it should, but the post that presumably disengages the clutch does not come out. Appears that it should be under some sort of pressure (either via hydraulic or spring), but am not sure. Any idea what the issue may be here?
I"ve put a pic of the arm that comes out of the transmission (and that the clutch pushes on to engage the trans) at the following URL, arm circled in red: http://www.walkerhome.net/img_0524b.jpg
Thank you!
