JD 1010 Charging/starting issues
So, I have a JD 1010 that I have been working on for some time. Generator was not working so I had it rebuilt. Good thing is that the generator light is not on now. Charged up battery and started tractor. Left it running and after about ten minutes it killed out. Does not crank over and battery shows about ten volts. Dummy lights come on at the dash, so I know that I have connection to power at the battery. What is going on? Could I have a bad battery (it is five years old? Any help would be appreciated.
10 volts won't crank it. Take and unhook the ground and see if it sparks when you do. If it does you have a dead short somewhere. Otherwise your battery is probably toast. 5 years is about all you get out of one now days.
To have discharged that quickly sounds like a bad connection or bad battery.
Charge the battery again, see if itholds a charge and have it load tested.
Then you can proceed to check the charging system.
Be sure to connect the polarity correctly and polarize the generator. The charge light should be on with the ignition on, not running, then go off running and up to speed.
The voltage across the battery should be 2 to 3 volts above the battery voltage running.
