jd 1020 control arm leak
jkremer
How do I go about fixing a hydraulic oil leak from the control arm? Can I remove the bushings and oil seal without going into the transmission case, or can I punch them out by going in from the other side? I have looked at the schematics and know what parts need replaced, but not sure how to accomplish the task. Thanks for any help!
Drain hyd oil
put L/D selector in "D"
remove 3pt draft arms from L/D control shaft
slide shaft out and inspect for wear.
remove old seals and install new seals
reinstall shaft and draft arms shim all side to side motion out.
I recommend changing hyd filter(if not done recently) and clean sump screen
refill with Hy-Gard oil
Tx Jim...Thanks for your time. One additional
question... How to I go about removing the
bushings/seals? Do I just get a long punch and
drive it out from the other side, or do I need to go
inside the back end in some manner. What special
tools do I need if this is not the case? Do not
want to damage anything and cause more of a problem.
Thanks again.
Yes you have to drive them out each side from opposite side with a long punch/rod.
FYI JD only recommended changing bushings if the hole was worn significantly. Repeated change makes bushing fit loose in trans housing offering another place for oil to leak. Be sure and check shaft for wear as this causes more leak problems than the bushings.
Thanks again. So you would just try a new shaft
first? If I still get a leak, change the bushings
or seals? There might be a little wear on the
shaft as it slopped around a little (The way it
was when I bought it this summer). What about the
seals/o-rings. How does one get those out with
out getting the bushings out? It appears as
though these are on the inside of the bushings in
my tractor???...they are kind of a reddish/orange
color and sit immediately inside of the bushing
collar. However, from some of the other postings,
and the shop manual, it seems as though there are
some seals that are external...I found nothing
like this when I removed the shaft; just a couple
of washers and end nut and that was it. Maybe
this is why I have a leak, no oil seal.
Thanks again for your continued assistance.
Whenever I work on something new, I tend to get
overly cautious as I do not want to make things
worse.
I use an o-ring pick to remove old seals.
No external seals just these parts required.
A4730R PACKING, -O-RING ADD 1.70 USD 3.40 USD
T22098 RING,SEALING ADD 5.99 USD 11.98 USD
If shaft is needed
L26932 SHAFT,LOAD CONTROL ADD 110.00 USD
