You said.. I would think the coil wouldnt care at this
point in the system and should produce a spark..
Oh grasshopper, Seek NOT to know the answers, but
to understand the questions.
The ignition coil works on the principle of a magnetic
field that builds in the primary coil windings and when
interrupted charges into the secondary coil windings
creating the spark. The primary winding are connected
to the two small terminals that the ignition power lead
and the wire from the distributor connect to. The wire
to the distributor has to ground to the chassis or
engine so the circuit can have a complete path back to
the negative battery terminal. This happens when the
points are working correctly and the two contact
points meet when the points close. When that is
happening the magnetic field is building in the primary
winding which is an electromagnet. Most importantly
when the point open or the circuit is interrupted the
magnetic field collapses. Since the primary and
secondary windings are placed physically close to
each other the collapsing field induces a high current
into the secondary winding creating the spark. So
whatever you have going on with your primary lead
from the distributor if it is just blowing in the wind no
spark can occur. If you momentarily touch it to the
something when the coil has power that will ground it
and complete the circuit. Then when it is removed if all
is right with the world you will get a spark out of the
coil high tension lead you pulled out of the distributor
cap. Hope this helps. To learn more if this link is
allowed you will get some information that better
explains all of this. It is from the red tractor camp but
the ignitions all work the same.
Edit: By some chance you are viewing in Classic View you will have to click the box in the upper right of the replies that says Modern View to see my linked info.
Something helpful
This post was edited by used red MN on 12/01/2023 at 02:42 pm.
