JD 1020 PTO live power
TJ in IN
I have a 1020 that the PTO disengages when the clutch is engaged. everything I've read is these have live PTO. I know your suppose to engage the clutch half way to stop the transmission and all the way to stop the PTO.
is there something I'm missing or is it possible that mine does not have the live PTO option?
1020's could have the "transmission driven" pto option. Also the the pressure plate fingers may be adjusted incorrectly. I'd look in through clutch housing inspection hole.
The 1020 was made with both,in the tech manual I have it has a transmission driven PTO section and a live power PTO section.Yours is probably the trans. driven or non live model.
the ones I have worked on have a dual clutch assembly. on for the pto and one for the transmission. push clutch down 1/2 way the tractor stops. all the way the pto stops.
(quoted from post at 06:57:44 05/04/11) I have a 1020 that the PTO disengages when the clutch is engaged. everything I've read is these have live PTO.
It appears either an overly economical individual ordered the tractor new with a trans driven pto. Or ordered it with a power reverser.
CLUTCH SHAFT AND PILOT™BR>(LESS PTO) (TRANSMISSION DRIVEN PTO)™BR>(LESS REVERSER)
Cart KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 T23061 SHAFT 1
2 AL28037 BALL BEARING 1 (SUB FOR JD8511, JD9464 OR AL24903)
3 T22198 SEAL 1
4 T22904 GUIDE 1
5 R26933 SNAP RING 1
In some parts of the country (mainly the South) alot of 1020's were sold without live pto. We use to sell alot of used tractors and bought one or two 1020 that came that way.
