Jd 1380 oil
ih844
Just started cutting with my jd 1380 swinging haybine with the hydraulic pto. Severed that small hose that goes to the pump, and dumped all the oil out. Wondering what oil it takes, and if the pump should be okay, it made noise for about 30 seconds then quit cutting for 5 seconds before I cut the power to it. No oil left, and found the broken hose
Also curious what that small line is for
A small line on a hydrostatic pump or motor may be a case drain line. Drain lines are often located near the shaft end of the case.
When you are getting the free download copy of the operator's manual, at the JD site Tx Jim gave you the link to, you might want to purchase the service manual for it from there.
