Mike(NEOhio)
- Location
- Newbury, Ohio
A few weeks ago I posted about putting one on a 1550. Finally called and it's still there. He's asking $3K, said he might take $2500. Fair price??
(quoted from post at 16:25:05 10/09/19) Id find a farmhand f11 lot cheaper easier to mount and suited about right for the weaker hydraulic flow on the Oliver
(quoted from post at 14:21:13 10/10/19) Did some internet searching this morning and it looks like he's asking about average. It's on a 4020 now and he said it's in nice shape. I'd change it to an open center valve and use power beyond, not remotes. No biggie to me if it's a little slow, I'll just be using it for some light grading around the place, moving rocks, etc. Not far away so I have to go give it a look at least. Main concern is what it will take to get it mounted.
(quoted from post at 01:50:05 10/12/19) Mike then mounting it would be fairly easy. You can more than likely line the frame up with either the top or bottom set of holes in the Oliver 1550 tub. The 20 3/4 would just be a simple washer spacer. The 18 1/2 would work well with two, one inch thick flat stock drilled with the pattern to cover both holes. Then use grade eight bolts. .
(quoted from post at 02:08:26 10/11/19)
The JD 148 loader is a longer loader too an this will put the loaded bucket further out than the JD 146 loader. So you will have less lifting force. [/color:917cb9f1b7]
JD Seller is incorrect. The 146 loader uses the same boom, masts, and bucket cylinders as the 148. The 146 does use smaller lift cylinders than the 148. The only difference is that the 146 will not lift as much which is fine for the smaller frame tractors. The reach with a 146 is the same as a 148, but it may not lift as high due to the lower frame of the utility tractors not the loader geometry.
Adding this a little late but may help a future readers.
