bowtieboy77
I have a JD 185 hydro with the fc540v Kawasaki engine that I acquired a few years ago. It has always been alittle difficult to start it does not like much choke and easily floods. It has bee getting slowly worse. When cranking it over it will back fire up through the carb then if you continue to attempt to start it eventually it will back fire through exhaust (sign of flooding) Once it is running it runs well but it will go through about 3 spark plug per summer season.
I have the carb apart now for cleaning but don't expect it to be the issue. I have found the compression spec to be minimum 71psi and my result is 50psi. So it does shoe the engine has some wear but I geuss my question is will 20psi drop in compression cause the starting issue I am having? Any help is appreciated.
