JD 2020 questions
anothername
I am considering buying a 1972 2020 diesel, unknown hours as the hourmeter does not work although the tachometer works. It stopped at 1195 hours, but am convinced it has way more hours than that due to obvious wear on many parts. There is blue paint under the JD green where it has worn off, can't figure that out unless primer was blue, is that unusual?
Has 3 shift levers, High/Low on the left and 4 speed on the right, one in the center that does not seem to do anything. What is it supposed to be for?
Injector pump is Roosa Master and is leaking around the throttle shaft going into the pump. Is this easily repairable and are parts available for that injector pump?
The left lift arm on the 3 point has worn enough to slip off of the ball joint and is rubbing against the casting. Can this be repaired without replacing the arm?
Thanks in advance,
Steve Wyatt
My 2020 lift arms were wore like that.
I centered the ball in the arm and welded a bead around the outer edge of the arm to hold the ball in.
I did that about five years ago and it is still holding well.
The center 'lever' is for intependand PTO, it allows you to engauge the PTO shaft anytime you want, the throtle shaft o-ring is available, it,s probably had on-road diesel fuel used in it, this fuel is a little different and causes the o-rings to swell up a little and then when the shaft moves it cuts the ring a little,better have someone who knows a bit about the pump to change it, it will most likely need removed, I have changed some of them on the tractor, but I think that the 2020 shaft will 'not' come out for hitting the engine block,,as for the paint it may have been owned by a county or township that painted it blue some where along the way,,the 3 pt arm can be cut of and a new ball end welded back on,TSC has weld ons that work well.
In regard to the injection pump - it depends on what model. They are all Roosamaster/Stanadyne, but . . . the early 2020s have DB pumps (all repair parts available). Then CB pumps (no parts available), and then back to DB/JDB pumps (all parts available).
For 2020s with the CB pumps that have been obsolete for years - Deere sells a kit to convert to the other model pump. The DB or JDB type pump has the trottle shaft passing through the main pump-body, sideways. The CB pump has the trottle attached to a long stem that comes out the back of the pump and operates with rack and pinion gears.
They all leak over time, regardless of what fuel you use.
Tach may of made it around once ? makeing it over 10,000 hours. Not unheard of.
And the blue depending on where it is ? likely came from battery acid reacting with the paint. Antifreeze can turn them blue or more commonly yellow too.
Replacement lift arms are available from internet and aftermarket suppliers and are not as expensive as you might expect -- in the $100 range depending on who has them.
JD green turns bluish when exposed to various chemicals -- battery acid, antifreeze, orchard pesticides, tire water calcium chloride, etc. can all change the yellowish-green to a bluish green.
I suspect the little tractor has seen a lot of use. That's not to say it isn't a good buy and a serviceable machine, depending on how it is priced.
