Hi All,
I welcome your thoughts and expertise with this. I recently replaced my 1979 John Deere 2040 starter. I pulled the Bosch starter out of it and found an off brand starter online for $120 that replaced the Bosch starter. I figured I'd gamble, as the name brand replacement appeared to be over $300.
https://tractorstarters.com/products/brand-9/JohnDeere/model-800/2040
Since I have a loader on the 2040, I needed to drain the coolant and oil, remove the thermostat, dip stick housing, oil filter, and adjust the alternator location to pull the old starter out. It was clear that the starter was seized and needed replacement. I put the new starter in and re-installed the above said parts and put new fluids in it. It fired right up and I was excited about it running again. Upon coming back to the tractor a day later I realized that the lights on the dash were slightly dim, which was odd since the light switch was off, no key was in the ignition, and I have never had an issue with this tractor having a slow drain to the battery or lights not going off from the dash. I am a novice at electrical troublshooting, but have a multi meter and can check continuity, voltage, and amps. I have a service manual and plan to dig into the electrical diagram, but have already found multiple deviations when I replace the ignition switch about 6 months ago between the diagram and the tractor itself.
The batteries were drained and I recharged them and the tractor fired right up again. I am now in need of finding a solution to the batteries being drained and the lights on the dash not turning off. I removed the negative terminals to the batteries in the near term. Do you think it was the new starter that did this? How can I check that this is the case? Do you think it would be more cost effective to now add a disconnect in the line as opposed to buying a name brand starter? Any thoughts are welcomed, thank you in advance. -Tom in Oregon
This post was edited by Bergmann on 12/26/2023 at 11:10 am.
