JD 2140 Starter
rusty6
Finally got the new A&I starter for the John Deere 2140 yesterday. Its quite an improvement on starting but still needs a little fine tuning to work right. It took longer to edit and upload this video than it did to install the starter.
New starter
So a bad key switch or wires from the key switch to the solenoid or relay and from relay to solenoid is my guess . Is there a neutral safety switch involved
(quoted from post at 23:49:16 12/05/20) So a bad key switch or wires from the key switch to the solenoid or relay and from relay to solenoid is my guess . Is there a neutral safety switch involved
Neutral switch is working fine but I've got to check the start switch on the dash and see if there is a relay in there somewhere. If not, maybe put one in. The old starter had a bad drive and weak cranking speed. Notice I didn't have to wiggle the steering wheel when it started this time.
She really fired up nice on the video if the neutral safety switch Is working then check the wires and connections in the rest of the circuit should be pretty simple circuit I’d think. I feel your pain on the front end loader it is definitely a love hate relationship
this my take and is what i do if a customer come in with a 2640 type tractor that has the two battery that have the ground to top of battery box i leave them in place but run a new ground from the exciting ground to the starter mount.. jd had a up date to put a separate solenoid on that tractor it is in jd parts.. i yes a ford style single polo one. i made a mount from the fuel filter to mount the solenoid to i don't and wont by pass safety start but you do need to ck the wiring going to it on top of transmission
(quoted from post at 08:07:41 12/06/20) this my take and is what i do if a customer come in with a 2640 type tractor that has the two battery that have the ground to top of battery box i leave them in place but run a new ground from the exciting ground to the starter mount.. jd had a up date to put a separate solenoid on that tractor it is in jd parts.. i yes a ford style single polo one. i made a mount from the fuel filter to mount the solenoid to i don't and wont by pass safety start but you do need to ck the wiring going to it on top of transmission
I changed the ground on this one from those two straps to sheet metal , now directly onto cast iron below the battery box. Yes, we are looking at adding a relay to the starting circuit in hopes it will allow the original switch on the dash to start it. For now I can work around it with a jumper wire but
This solenoid/relay is what I'm looking at getting. Recommended to me by a long time heavy duty mechanic who has installed them on other tractors with good results. Its from a 2090 Case tractor.
The 50 and 55 series JD utility tractors have a solenoid similar to that mounted behind the dash, above the batteries. You might be able to fit one of these to your 2140 with the correct factory wiring.
Ben
(quoted from post at 14:25:57 12/06/20) The 50 and 55 series JD utility tractors have a solenoid similar to that mounted behind the dash, above the batteries. You might be able to fit one of these to your 2140 with the correct factory wiring.
Ben
Thanks. I did a search at jdpartsonline and found the part number for the 2155 starter relay. It is RE164448. The image looks pretty much the same as the relay for my 2090 Case. So if I get one of those and it doesn't help the John Deere, at least I will have a spare for the 2090.
