jeff deere
What do I need to look out for in buying an older baler? I don't plan on custom baling, just 200 bales of wire tied straw a year.
jeff deere
IIRC a JD 214W baler is very difficult to work on tying system. IIRC it ties on both ends of bales.
A JD 214WS has twister hooks & grippers same as later JD models. They were as dependable but lower capacity than later JD models.
A 114W and 116W tie on both ends of the bale, not 214W. The 114 and 116w's were nicknamed "Sidewinders" as the bale comes out the left side. They were hay eating fools in their day!
You are correct about a 214WS is about the same as more modern balers
Roger in Iowa
Have you ever seen or used a JD214W sq. baler?
Please explain to me why a 214W uses 4 BP14132 roller(2 for each needle) as needle rollers and an AM3223E needle instead of an AE11227 needle like a 214WS with one roller per needle?
Why did W have knotter boxes AM3441E instead of twister shaft & hooks?
Why were the wire boxes smaller on a W than a WS to accommodate the same type of rolls of wire as used in a 114W & 116W?
TX Jim,
I worked at the JD factory that built balers for nearly 30 years. I never once ran across a 214 baler that used the same system used on 114w and 116w balers. I learned something, if true.
The size of wire coils was because there was no standard set by ASAE. The larger size was set later but the earlier machines could not be abandon, so both sizes were adopted.
Roger
Roger in Iowa
I could be wrong about the resemblance of 214W to the earlier series. On JDparts.com the tying system on a 214W reminds me of what the 114W/116W tying system looked like as I think both used the double roller needles.
BUT a lot of water has run under the bridge since I've seen a 114W/116W
What years did you work at Ottumwa? I hauled some loads of hay equipment for a dealer from there in the 80's.
Hi Jim,
I worked at Ottumwa from '73 to 01'. I worked service dept, experimental, DTAC, training, and marketing. Also had golf and turf support for awhile.
If the baler had the two rollers on end of needle, it could have been the older style of "twisters'. I had never seen one. Raked hay in KS for a 114w or 116w. Friend has a 114w to restore, but is rough.
Most wire balers are in your neck of the woods and OK.
Roger
Roger in Iowa
The parts diagrams of 214W tying system remind me of 114W/116W tying.
Not many twine sq balers sold down here.
You must have been working at Ottumwa when I hauled loads out of there for JD dealer I worked for. Coldest I've ever been was in Osceola,Iowa!!!!!!!!!
Did you know an engineer named Denny Amstey(sp)? He worked in experimental dept.
Roger in Iowa
I talked to Denny when I ran an experimental shear-bolt drive shaft and spiral starter roll on a 435.
Did you know the Campbell's from Maypearl,Tx that ran experimental hay equipment for JD?
