JD 2440 stuck in low range
LeeT
Can't move range selection to neutral, high or park. The gear shift will move ok and goes into five but can't get range shifter into park.
The tractor will move in low range.
Of course, not being in park the engine won't start now either.
Any ideas?
Thanks, Lee
Lee,
Very common problem. It has a broken shifter rail. Unfortunately you have to split it to fix it. As Tx Jim says pull the shift cover and take a look.
John
I have seen some where preveius repairs went down trough the top cover hole and welded them back on. These tractors do have a lot of bad ideas built into them, all the way thru.I think a freshman VO AG class could have done a better job desighning them.....
Tim S
I couldn't agree with you any more. The people that run JD utilities that have never diagnosed/repaired them will never understand and want to argue.
IMHO hydraulic design is daylight & dark between JD rowcrop & utility tractors.
