JD 2510 diesel
It should fit... the only issue might be if the engine you have has a turbo, there may be some interference with the hydraulic valves if your tractor is equipped with the dual valve. If I remember correctly, it isn't such an issue if you have only one valve.
Good luck- sounds like a fun project.
