Bristol121
So a few years ago I purchased this gem. Mechanic inclined but not much on tractors. Auto engines trans restore ect my backround
1984 2640 with reverser
So this thing was a rattle box. Loud noisy in gear box. Did some trouble shooting and thought possibly clutch was bad and possibly trans pump. Spilt tractor at clutch, replaced everything, clutch set up by local dealer. Replaced clutches and seals in reverser and front drive. Split again replaced all o rings and seals and trans pump.
Finally ran it yesterday. Good news is its quiet. Bad news I still have a hydraulic problem. But not as bad as before. Basically I will loose hydraulic function after it gets hot. I did not have loader on it yesterday to run it through it paces hard but ran the gravel box on driveway for prob 45 minutes at about half throttle in 5th gear. The three point still shuttered two times. Didnt loose hydraulic. But the three point basically rattles up and down in a quick fashion.
There is a barking noise and seems like still a possible starvation or cavitation or main pump is the real problem.
Would like any thoughts as to what to check. I didnt have my gauge hooked to the main pressure yesterday and I probably should have.
