JD 2640 starter solenoid
When I start my 2640 I turn the key and the starter starts to engage to turn the engine and then its like something is just spinning.
Sometimes I have to turn the key several time to get things to engage to get the tractor started. Is this the solenoid or starter. About 6
months ago just changed out the solenoid. Any type of feedback appreciated or suggestions.
It could be the starter, the solenoid or the ring gear. Take the starter out and turn over the engine 360 degrees and inspect the ring gear. Look for worn or missing teeth.
Ditto on removing starter & lubricating starter gear. If negative battery cable is the type attached to battery box I suggest to relocating attachment to engine block or starter mounting bolt.
