JD 2640 tach cable replacement
Where does the cable on a 2640 connect to the engine. It looks like it connects under the battery case. If so how is the battery box removed since it looks like it is connected to the dash. Any comments or information is appreciated. Have googled looking for info but found very little information.
The cable connects into the clutch housing flange in line with the rear end of the camshaft.
On the right side of the tractor, position yourself so you are looking at the split between the clutch and fly wheel housings. Look just above and behind the 5/8 bolt head at 2 o'clock of the clutch housing flange that holds the clutch housing to the flywheel housing, and you will see where the end of the tach cable housing is screwed into the clutch housing flange.
You can change the tach cable without removing anything, other than the cable assembly itself.
