JD 2750 question
cmilne
Hello: I am wanting to mount a NH 616 disc mower on my JD 2750. The 616 manual shows stabilizing bars and chains but my 2750 has sway blocks. I have not figured out how to adjust the sway blocks yet to a wider setting. Do I still need the stabilizer bars if I have the sway blocks? If so where can I get the bracket that mounts on the axel for the end of the stabilizer bar? Thanks for the help.
Being a CAT II three point hitch it should fit ?
The sway blocks unbolt and are usually a given a 1/4 turn to obtain the wide or narrow spacing .from CAT I or CAT II.
https://www.newhollandrochester.com/wp-content/uploads/pdf-front/1523644153833167432.pdf
