SKYBOW
Having tractor trouble. 6 degrees with windchill of -20. Had tractor in barn with block heater and magnet heater on oil pan. I've used the addative in the fuel to prevent gelling. Tractor started but seemed to smoke a bit more than normal. Rolled ahead for about 10 feet and the tractor seemed to lose power. I added power and the motor died. Put propane heater on fuel filter for a while. The tractor started and seemed to be fine. Got about 200 yards out in the pasture and it lost power and died again. Put 911 in the fuel filter. Took of line from transfer pump to tank and blew compressed air through it in case it had water frozen in it. Took off the line from transfer pump to filter. It was not pluged. When I turned it over with the line off the transferr pump seemed to be pumping fuel OK. Rented some extension cords from the renta center. Put the block heater and pan heater back on. After it had warmed up the block I tried to start it but it will not fire. I sprayed starting fluid in the intake. It will turn over and eventually fire but only runs for a couple seconds till the ether is gone. What have I missed? Not totally sure I am priming it correctly after I removed the filter. Does the diesel look milky when it is gelled? How do I get it started?????
Thanks guys
yes the diesel will look milky when gelled. you probably need new fuel filters and more anti-gel. i wouldnt use howes as im told it doesnt work with low sulfur diesel.personally i use power service but to each his own. fill new filter full of antigell not fun on deeres glass filters. then put it on trying not to spill very much.add more antigell to the tank too. for me i use a little more than what the bottle says to. then hand prime the filter. and with all the heaters on it hopefully it will start and run. will probably run pretty rough for the first minutes but should come out of it. good luck its never fun once theyve gelled up
number 1 diesel. the more you get into it, the easier it will be to get it running. additives now are a waste of time. oh; change the fuel filters. good luck. could always wait for it to warm up.
Now that you have it out in the field (don't do that again-let it run for a half an hour by the barn next time) put a tarp over the whole thing and weight it down pretty good and then stick a torpedo heater in between the rear wheels. You can get that whole tractor hot to the touch given enough time. Be careful that you don't melt anything like rubber parts. While it's doing that, go get some winter diesel. We use "Arctic" diesel around here in the winter. That stuff doesn't gell until about minus 44. #1 if you can't find arctic. Get as much of that in the tank as you can. I always fill the tank on the tractor with winter diesel in November, clean and replace the filters and then use the mfg block heater and battery boost charger for starting and I've never had problems starting or gelling. Never. Short of that, you're just going to have to keep the engine running from Nov thru March. That'll work too, assuming the filters are close to the engine.
