JD 2940 hi&low
Aaron R.
My JD 2940 was sitting for a few years. When I got it going the high low shifting was working fine now when I go from low to high it boggs down the engine won't shift into high. I also have a hard time getting it into 1st and 3rd gear. I checked the hydraulic fluid and it was full.
Not saying this will fix it but change the filter and wash out the screen in there .See if that helps with the hi lo deal. They are clutches for that shift if it is the lever to the left side of the steering column on it. IF just the 2 levers between your feet then it probably has gotten moisture up in there from setting and now the crude is working out into the lever travel.
